Briar Hill Brittanys
How to buy the right wood stove . Some more good information to ponder. Mark
[*] I am doing to supplement heat not replace heat, so I do not see needing any more then 2 cord a year. I would say in three years the stove will pay for itself. I agree if you are burning 4 or 5 cord a wood in less then 2500sq foot home it is not the right set up or you need to more insulation
I posted something earlier about an enclosed forced air wood furnace but after looking at the floor plan and reading all these other posts I am at a different opinion.
I am not so sure a brick fireplace with an air tight insert wouldn't be a better solution?
Reason I say this is they are considered a lot safer than free standing wood stoves to insurance company's and IMHO they look better and add value to the house.
Granted the cost will be considerable compared to just cutting a hole in the roof which I am NOT a fan of a fireplace will generally have a brick flue on the outside of the house with an outside clean out as well. just my 2 cents
My son put a wood burning insert into an existing fireplace. Aside from some fan noise, as Eddie mentioned, it produces good heat and is very attractive.
Downside to any wood/pellet burner needing elec. is when the power is off, either you need a generator or you can shiver while looking at the stove That has always made me avoid burners that rely on fans or elec. controls.
Well as always you guys have placed a lot of information on the post, (which is GREAT! and thank you) I think it has been interesting.
An outdoor wood boiler for is not the answer too much wood and too expensive to heat a 1500 sq foot home. It is just not a good return on investment to heat that small a house. If I was heating my barn, garage and house I might consider it but really do not want to bother with that much wood. If I was heating about 5000 sq feet I might consider it. I believe I stated this in my orginal question. But anyways this is my reasoning.
Ok here are lessons learned for me!
[*] I am going to get a wood stove.
[*] Chimney will go Straight thru roof. no bends better draft
[*] Ash pan in the stove.
[*] Get one that is approved for mobile homes makes the best sense as it
gives me more freedom of placement.
[*] No fan on stove I already have a ceiling fan in the living room and will install another in the dining room will move air pretty well with that.
[*] I live on 106 acres and 35 acres is woods, I have hedge rows which I wish to thin and get rid of, plus 35 acres of woods. So as far as trees to cut if I choose I can cut what does not have to be split if I want to. Also a splitter for my tractor would not be that expensive and a friend has offer to loan me his. The key word here is fellows FREE
[*] I already have two tractors a massey 165 and john deer 5103 Both have a front end loader. The JD has forks and root grapple. I also have a **** spreader that has been converted to a wood wagon. I also own three chain saws, chains, along with john deere gater and mule, and have used an ATV to skid logs on occassion.
[*] My plans will be to wait till the leaves start to bud and then cut the trees so as the leaves dry up they help the wood dry. Once I get it up to the barn I have very big parking area for my kennel with shale parking area to lay down trees, not in the mud will not dull saw. During the summer as I want an outdoor fire I will use branches from the trees for my little fire pit on the deck. Will get rid of brush.
[*] Once I am ready to cut wood I will take some kind of pallets and add three sides and roof. I will pay a kid to stack wood in the pallets, as it gets cut. Once I need wood will lift the pallett on the deck with JD which will be about 3 feet from outside deck door, which is right next to wood stove, once inside the house the stove will be right beside the door. Will have an area big enough to keep a days wood inside. I agree with having to carry wood thru the house that is messy, and up any steps gets old quick. But if I only have to carry it 3 feet outside the house, and 2 feet inside that is not bad.
[*] I have enough scrap tin from past projects to cover and side the Wood pallets a few support 2X4 from what lumber I have and it should not be too bad. If I can get a big pallets I can almost get 1/2 cord a wood on one pattet. it only has to 4X4X4.
I am a little confused about size. Eddie had said go bigger, but it seems like some of you said go a little smaller. So I am bit confused on that part. I know if a fire is hot you do not get a build up in pipe. So I am leaning a little toward maybe something that will heat up to 600sq to 1000sq ft.
I would not mind a little more conversation on the size for square footage.
