murphy1244
Epic Contributor
- Joined
- Nov 25, 2011
- Messages
- 20,039
- Location
- Ohio
- Tractor
- Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
Adding or Replacing a stabilizer bar
I was bush hoggin in the back field and there where quite a few saplings I was chewing up. One of them snagged my front lynch pin going to the right lift arm on the three point hitch. The bar fell and dug in and bent to almost a U shape. I'm going to heat it up and repair it next summer. In the meanwhile I went to TSC and bought two of their "country time" adjustable stabilizer bars.
Notice in picture two there are four holes to select to mate to your stabilizer bar. I've seen kits that offer to flat bars and attachment points similar to mine.
If your tractor doesn't have stabilizer bars, you should really consider investing in a pair. It's not the difficult to install the hardware and sure keeps the rear implement from doing the rumba behind you. I have a few pictures showing what to do on my old MF135.
I measured from the front point to the rear lift arm swivel which was apporxiamtely 33.5 inches. I adjusted the bars to match attachment points. I then put a slight bend in each eyeley in opposite directions to make them fit better.
View attachment 290319 View attachment 290320 View attachment 290321 View attachment 290322 View attachment 290323
TSC sells these for around $39 each which is what I'm using. I'm going to paint them red except for the ends.
These are heavy duty pins TSC sells which have twice the strength of their cheap ones. I now have them on the front lift arms.
Lookin good, thanks for the lesson.
Murph
