Howdy Robert,
I was curious how your sheet metal turned out? Did you weld it all together so you can tip it forward? Have a good day.
v/r
Mike
Hi Mike. Yes. I welded all the front pieces together and it worked out great. The vertical side pieces and the horizontal side pieces are both bolted on. I decided not to put a circular mount and keep the slots. I can loosen those front lower bolts and still hinge all of the sheetmetal forward.
Right now I've got three things I'm doing. I'm replacing the serial plate on the engine block and replacing the fuel tank. The fuel tank was patched over a patch and decided to just get a new one. The sediment cut off would not screw into the new tank fitting. It seems the old tank had a brass outlet fitting and had been die cut to except a standard 3/8" thread. So guess what. The new tank will have to be done the same way.
I've got the tap and a new cut off. Waiting for the paint to cure. Today is going to warm up, so I'll put the tank in the sun and it may be ready to install tomorrow. I'm going today to pickup my rivets I ordered for the serial plate. Steiner wanted $.25 each and I bought a 100 for $5.84. They are a nail in rivet like the original.
I had the tractor out and made a few laps around in the driveway, a week or two ago when I discovered the bottom of the fuel tank was wet with gas. (patch).
Still looking for that cloud over my head. I noticed the tractor hesitating a little bit when accelerating. So a few days ago I knew I had to remove the distributor to get to one of the serial plate holes I was needing to drill out. I marked the distributor to make it easier to reinstall. I removed the distributor and put it in a vise and started taking it apart.
What I found shocked and amazed me. This type of distributor is a 1112-643 which says it's for a Special. I have a Deluxe. It has twin weights on each side.
They where all frozen from the springs failing and jamming into the distributor wall. The springs had cut three nice groves into the inside wall. I dumped out about a teaspoon on metal shavings from the distributor wall. I cleaned everything up and the distributor shaft had no side play so basically no damage was done except for the groves. I ordered some springs from Summitt Racing out of Knoxville,TN.
It seems they are sending me three sets. Light, Medium and Strong. The specs shows a power curve in degrees and the motor accelerates. The only way to check this is to accurately read the RPM's while using a strobe light to see the visible timing marks in the peep hole.
I've also ordered a Photo Digital Laser Tachometer to check my tachdrive and to check the power curve to use the correct set of springs. AGCO not longer sells those springs so don't ask. Delco-Remy distributors are still supported in the automotive industry. So there is your source. I found a kit with three sets of springs on ebay for around seven dollars. Cheap enough. I could probably go to NAPA or Autozone and get some springs but finding the right tension is the key. Grass cutting time it quickly approaching and need to get the tractor out of the garage to get the lawn mower out..
As Paul Harvey used to say.
"Now you know the rest of the story" -kid
