Just did it earlier this month. Couple concrete blocks and some scrap 2x6s.
Jun 19, 2022 / Removing a single front tire? #11 4 462 New member Joined May 10, 2015 Messages 8 Location NW Florida Tractor Kubota M7040 Just did it earlier this month. Couple concrete blocks and some scrap 2x6s.
Jun 20, 2022 / Removing a single front tire? #12 oosik Super Star Member Joined Aug 22, 2012 Messages 19,416 Location AMBER, WA Tractor 2009 Kubota M6040 I use jack stands.
Jun 20, 2022 / Removing a single front tire? #13 B BLSXJ Gold Member Joined May 26, 2016 Messages 270 Location Pembroke, Ontario Tractor Kubota L3400 definitely block the axle. if you let it dangle... and remove one tire... the axle will pivot up (smacking my knuckles) when you remove the one tire
Jun 20, 2022 / Removing a single front tire? #14 LS Tractor Owner Super Member Joined May 1, 2017 Messages 7,323 Location Edgewood, NM Tractor LS XG3025 TLB, Previously MT125 TLB, Craftsman GTS6500 In agreement with the above.... take the minute to put jack stands under it.
Jun 20, 2022 / Removing a single front tire? Thread Starter #15 OP B BillP2 New member Joined May 11, 2019 Messages 14 Tractor JD 5055D Thank all for replies. Put the jack stand under it, removed the offending tire, got it repaired and re-installed. Worked perfectly...no blood or curse words.
Jun 20, 2022 / Removing a single front tire? #16 LS Tractor Owner Super Member Joined May 1, 2017 Messages 7,323 Location Edgewood, NM Tractor LS XG3025 TLB, Previously MT125 TLB, Craftsman GTS6500 Well, there you go! Good job!
