SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,163
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
AlanB said:I loved the Crescent wrench debate,
So I asked Crescent for their answer.
Alan,
All Crescent branded adjustable wrenches have an arrow indicating the proper direction for use. The proper direction would be; as the wrench is held in front of the user, the moveable jaw would be on the under side. The wrench is used in a downward manner toward the moveable jaw.
This puts the load on the fixed jaw. When used away from the moveable jaw or opposite direction the load is then put on the moveable jaw (weakest part).
Regretably this answer from Crescent is wrong from the standpoint that they have not given the correct reason for turning the wrench in the "correct" direction. I sent the following note to Skyco and Jimmer about a week ago:
"Unfortunately, the flavor of the thread on the subject has served to curb real inquiry. I finally went ahead on my own and applied identical torque both ways, at an abusive level. Neither was close to a slip tho. Below is the P/M I sent Skyco about it.
"I understand the point you made, and share the direction of thought with you. However the wrench is stronger when used such that the fixed jaw is away from you when pulling even tho the movable jaw encounters the bolt flat further out. The reason for this is flex in the neck of the handle where the adjuster is held. When pulling toward the movable jaw this flex tips the jaw inward more and more as torque and force increases, actually tending to squeeze the nut. The jaw actually braces the handle by reacting from the nut back into the handle. - - When used the other way the flex tends to splay the jaws apart. Even tho this direction spares the movable jaw by applying force near the support point it really is strong enuff to take it either way. The situation of design seems to balance the respective benefits such that the wrench has very near the same torque ability in either direction. Not quite tho. In worst case situations pull toward the movable jaw. Its strong enuf to take it even tho the whole system ends up leaning on it. "
Crescent, in their predigested answer, does not give credit to the inquirer and gives an answer that stumbles over physics. In truth the strong jaw is more highly stressed when the wrench is used backward - and it flexes causing the small splay I observed and measured.
larry
