Junkman
Super Member
</font><font color="blue" class="small">( <font color="blue"> I would say that as far as tire load goes, you are probably right. but how many compact owners exceed the tire load?
As far as the conforming, from what I have seen, the weight of the water on the bottom of the tire vs the cast load through the sidewall is the difference. Tires are designed to carry their loads through sidewall not the type of load that the water supplies to the contact patch only or should I say in large part. </font> )</font>
The liquid inside of the tire is actually a help to the sidewall of the tire. Liquid unlike air doesn't compress so the liquid makes the sidewall stiffer and less likely to break the tire bead. This is one of the things that I have noticed about filled tires vs. non filled tires....
