cowboydoc
Super Member
- Joined
- Dec 23, 2000
- Messages
- 6,737
- Tractor
- JD 8320 MFWD, JD 6415 MFWD, FEL, and cab, John Deere MFWD 4600, John Deere 4020, John Deere 4430, John Deere 455 mower, Deutz, and Gehl 4610 perkins skidsteer
Re: Loading vrs Not Loading
I don't know about these little compact tractors on acreages but from a farming standpoint you are much better off with weights. There are many times that the weight has to be varyed depending on what you are doing. Not many tractors these days for farms or ranches are filled with fluid anymore. The choice for the most part is to use weights so you can take them off and on as necessary depending on the field conditions and what crop you are producing. About the only time you fill tires anymore is when you are going to have a dedicated loaded tractor, usually with 4wd, that you aren't going to do any crop work or will be using the tractor where compaction isn't an issue.
