dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,188
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
Bye the way DF, did you re-adjust to 2611 psi per manual or
leave it higher.
I set it to about 2700psi. 3000 psi is WAY too high. I warned the dealer about that and I was
told they would check pressures when new units came in. That's when I found out final
assembly was done in Fargo, ND, and not at the dealer's place.
I was surprised to find the spec differed from Kioti's spec, which is only printed in the service
manual. I saw a PDF of the Bobcat manual at the Bobcat display at the World Ag Expo. I do
have the Kioti service manual.
http://www.tractorbynet.com/forums/hydraulics/155427-why-you-have-check-those.html
Any work port is more than adequate to measure RV pressure, as long as you cause the
pump to go to relief, as I stated above.
