buickanddeere
Super Member
There are "big block" Vanguards that are 35hp...
Make mine a diesel pleaseee!
SR
Why ?
SR
There's plenty of old industrial gas engines around. Certainly lots of gas tractors between 30-60 HP. And of course the 4 cylinder Wisconsin engines in skid steers and fork lifts. And there's lots of 6 cylinder Ford 300s still working. I've used one on a big scary Vermeer 1600a wood chipper. I'm not positive, but I'd guess it was tuned somewhere around 60hp. It was carbureted and liked gas, but it would work hard all day at 27-2800 RPM.
Wasn't there quite a bit of torque on those old Ford 300 engines? Large rotating mass and all of that. Would seem like a good match for a chipper.
Why is a Tier IV diesel better than a 2015 Fuel injected or direct injected gas? How much does diesel and gasoline cost where you reside? Do gasoline engines have cold weather starting problems or jelled fuel filters? How economical is your diesel when the emissions equipment requires service after the warranty has expired?
More toque and better fuel economy. Gas $1,68 diesel $1,85. I don't have weather cold enough to jell either fuel. I don't have any of the emissions **** My F series Kubota has a 25 hp diesel and a 60" deck. My Dixie chopper has a 25 hp Kohler and a 50" deck. The Kubota cuts any grass you can get under the deck. The gasser with 10" less deck has to be treated gently to avoid stalling. Not even close to the same power output. The diesel burns 1/4 as much fuel. Some of my Diesel engines sit the better part of the year unused with untreated fuel and no problems. Let's see you try with gas. I'll even let you use ethanol free gas ( which cost more per gallon than diesel). Why don't over the road trucks use the fuel injected gassers that are so good? Maybe because they don't have any toque and get 2 mpg? When over the road trucks convert to gas you might have a case. Until then quit trolling threads. You aren't going to convince us of the gassers are as good nonsense. Gas motors are cheaper, but there is nothing better about them. Why don't you go buy a fuel Injected tractor and see how it works.Why is a Tier IV diesel better than a 2015 Fuel injected or direct injected gas? How much does diesel and gasoline cost where you reside? Do gasoline engines have cold weather starting problems or jelled fuel filters? How economical is your diesel when the emissions equipment requires service after the warranty has expired?
Better torque, use less fuel, I have NO cold weather starting problems with mine, nor have I had any problems with them as they age (of course I'm not running deeres either lol) Fuel last longer, I have ZERO problems keeping it for extended amounts of time. The list goes on and on...
I have numerous gas and diesel tractors, and engines, the diesels have been better for me in every way...
I would NOT buy a gas tractor if they offered it, I also do not have any diesels that need re-gen ect... No need to, the ones that I have will last me until I take my eternal dirt nap!
SR
