Egon
Epic Contributor
Paradigm Shift and Paradigm paralysis.
A well acclimatized company man eh.
Who doesn't like the smell of diesel, and to blow some black smoke?The best part of Diesel is I don't have to store gas in the barn.:thumbdown: And I just loooove the smell of Diesel in the morning.
Why is a Tier IV diesel better than a 2015 Fuel injected or direct injected gas?
How much does diesel and gasoline cost where you reside?
Do gasoline engines have cold weather starting problems or jelled fuel filters?
How economical is your diesel when the emissions equipment requires service after the warranty has expired?
My Kubota can still do it. The old 7.3 ford can still do it. The old army truck is real good at it. The EPA hasn't taken all of my fun away. Just because you can't buy a good diesel and are obviously jealous doesn't mean I can't have one.EPA took that fun away. In Ontario there is a 1-800 snitch line to rat out drivers rolling coal.
I did a little checking and surprised myself. I was wrong. Indeed, the older tractors with gas and diesel engines of similar displacements had the same maximum RPM and delivered similar peak horsepower. All I can infer from that is that they had the same torque at max RPM which would translate to having the same BMEP. With the marked difference in compression ratio, it seems that the only way that could happen is if the diesel fuel supply was restricted to run leaner and limit the power. Maybe this makes sense since the frame and drivetrain were designed for a certain HP and perhaps the manufacturers figured that if you were in the market for a 50 hp tractor, that's all you needed and the diesel selling point was the greater fuel economy.
