tugboat-2
Platinum Member
- Joined
- Jan 12, 2007
- Messages
- 576
- Location
- ERIN, Ontario, Canada
- Tractor
- Many over the years, + '05 JD-4410 TLB, but quite proud of my big green "Rolls": AKA: 2006 JD-3520 Cab, HST, Tunes & 2-way tiltmeter, Cobra communications and 6" (x2) rear wheel spacers for a lot less pucker-factor!!
Mega Me: Sorry to see this situation, but happy to know you are OK! You must have had a firm grip on your beer to avoid a spill! I'm curious about the title, did you suspect this might happen?
Do you mind if I take a guess as to what happened? Looks like the tree you cut down, fell across the creek. (as you said). I'm guessing you chained the butt to one of your bucket hooks and started backing up.
However there is a slight rise in the ground and the tree butt kept snagging, so you simply raised the bucket as you backed up, lifting the butt a little.
Then, either you started turning on purpose, (or without noticing it) the tractor slowly got turned just enough (to put you on an angle to the pull) as you kept raising the bucket and the tree kept "lurching" ahead. The tree's final "lurch" pulled the "high" bucket (on sort of a sideways angle) and over she went!! Down with a bang! Pretty scary moment!!
Please let me know if this is a "fairly" accurate guess. Right or wrong I enjoy "trying" to figure things out from pictures. THINKING BACK, to the moment,...(as it began to tip),... do you think "dropping-the-bucket-fast" would have avoided the roll? (Dropping the bucket would have "let-go" what was pulling you over, AND set the weight back on the rear wheels and back-hoe). Providing my guess is correct?
THANK YOU for sharing this. Could save someone else serious injury or worse! THANK YOU as well for the "Services-Rendered" in your daily (nightly) work!!!! Good Man!!
Hope your tractor will be ok without toooo much work!!
CHEERS,
. . tug
PS: you might want to take a peek at "The Big Flip" (similar to yours). It was at the bottom of page 1 of this Thread. Might be page 2 by now? May be some help to you, Good luck!
CHEERS,
. . tug
