kenstrac
Platinum Member, RIP
You have a unloader valve on the pump,when the key is in the start position it energizes the valve, when the key is released to run the valve is de energized.
Check the voltage at the valve in start should read 12+,you may want to try jumping the valve to see if you can hear it move in or out.
If moving the steering wheel has an effect you may have a loose wire in the dash that controls the valve.And yes yo do have a closed center hyd. system.
