DavesTractor
Elite Member
MarEng, thank you for taking the time to write up the procedure. Your efforts will help many others. Well done. Dave
Reg,
I like your idea, how would I find the taper on the new part? Then can I just order new tie rods? and if so what is the price of the new tie rods and or plates for comparison?
Thanks Bob
These are heavy tractors with high lift capacities, and let's face it, we use them hard. Even so, I'd like to see overkill in this area, perhaps twice the size and we would never see the failures.
If I remember correctly, the upper plates are substantially larger, as well as the overall makeup of the tie rod. I would not recommend enlargening the size of the plates because they can come under substantial stress during operation or the tractor can be operated at speeds on the road that are considered fast.
Maybe and maybe a drilled & reamed out top plate would be the next to go from overload once a bigger tie rod end is in there and that no longer breaks ?
So, what goes next, after the tie rod end and plate are beefed up.
