oldnslo
Super Member
Ben755
First silly question, I presume the FEL operated correctly at some point? Is this correct?
Do you have the "float" option on your loader? If yes does this work?
Does the loader raise at the same speed when moving the joystick to raise or lower?
one possibility comes to mind that could cause this type of failure? You have a regernerative spool in the lift lower function of your FEL. If this true The FEL should raise faster while either trying to raise or lower. Also you should not have the float function since most directional valves have a maximum or four positions.
