J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,928
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
No, actually, I do not see any advantage in engine lube filters that can filter smaller particles. If you have a working air cleaner system, there are no smaller particles to remove. Air cleaner elements have a pore size distribution ranging from 1 micron to an upper range of 15 micron. Engine lube filters made of cellulose generally range in pore size of 40 - 60 micron. Particles of that size circulating in your lube oil have no effect on engine rotating and sliding components. To have a number of particles that size to cause issues means there is no air cleaner working in the system. The result of that will be high cylinder and ring wear. Why would it matter to remove those generated wear particles when the damage has been done. Fix the air cleaner. Don't get a more efficient lube filter. The company I work for has microglass lube filters. They are an added cost with no benefit. Either stay with cellulose or go to filters that combine a full flow with a bypass. The only advantage a synthetic full flow filter has is that it allows higher filtered oil flow during cold startup. Cold can mean oil that is at 100F even. Otherwise, the bypass valve in the engine lube filter circuit opens to provide an alternate flow path for lube flow because the cool oil viscosity is too high to have sufficient flow and resulting oil pressure. Other than that, synthetic full flow media filters are a waste as you pay a lot more and get not much in return.
I agree with you about the filters as used with engines. But consider this, in dealing with these synthetic filters in hydraulic systems. Our machines the Power-Trac, and other large machinery us motor oil as the hydraulic fluid, synthetic or whatever. and as such, should be kept as clean as possible. Some of us have gone to great length to filter, and we do it sometimes better than the manufactures, using bypass filters , in-line high pressure filters, and external filter carts.
The question might be, is a synthetic filter, with the same micron rating, any better, about equal or not as good? , and for the money , is it worth it.
