fieldserviceengineer is most correct about bypass filtering.
It seem apparent that good number of people have never seen any bypass filtration. If you know the concept of bypass filtration, you would know from good common sense that it is a good thing. And yes, it does cost more. The bypass filter on my engine was 1 micron, and it would filter everything larger than 1 micron, and that include the normal crud laying on the crankcase of any engine. If you have ever seen the comparison between the same engines with and with out bypass filtration, then you would know what is so good about bypass filtering. I don't know for sure, but probably a synthetic bypass filter would be even better, but in reality, 1 micron is 1 micron. For those that don't know, a bypass filter only filters a small portion of the oil pump volume, but over time will filter the complete oil supply over and over. If the bypass filter is added to a new engine, then you have the best system for filtering that you can get, and you will probable never see any crud on the bottom of the engine. However if you add a bypass oil filtration to a used engine , it will begin to filter the old oil down to a 1 micron level and throughly clean the oil, but will not breakup and release the crud on the bottom of the old engine. You can add a bypass to any engine, and it will be better than it was for sure. Just MHO.
Again, in theory but show me some engine will last XX% longer then not using a bypass. That is my point..
Then show me "you will probable never see any crud on the bottom of the engine". You can use a dino oil and a FFF along with LC20 and get that at 1/10 the price.
