TC-33 Blowing the #2 Fuse
   / TC-33 Blowing the #2 Fuse #21
How could we check to see of there are any TSB's out from NH on the issue?
   / TC-33 Blowing the #2 Fuse #22
If it were me I would use nothing larger than a 10 amp breaker until the problem is found and resolved. Intermittent problems can be the hardest to find, good luck.
   / TC-33 Blowing the #2 Fuse #23
jinman said:
EDIT: Here is a quote from Spencer200 about a circuit breaker replacement available from New Holland:
The 7.5 amp fuse has been replaced with an 8.0 amp circuit breaker because of repeated failures. The circuit breaker part number is 86610928 dealer list price is $7.31 but should be covered under warranty by a good dealer.
Thanks for the part number. http://www.messicks.com/ sells them for $12.19 plus shipping.
   / TC-33 Blowing the #2 Fuse #24
jinman said:
I agree with Mike. That's a dangerous way to "troubleshoot" this problem. You might end up burning up more than the faulty item; like wiring or switches.
I agree completely.
Bob
I’m going to stick a 15 amp fuse in and go from there. I still keep thinking that maybe the fuse is slightly underrated for the circuit. When you forget and leave the tractor in gear and try to start it, you hear a faint click, like a relay of some sort. That is the sound I hear and then the snap of the fuse. There is absolutely no attempt by the starter to pick up.
   / TC-33 Blowing the #2 Fuse #26
Why not stop by your local auto parts store and get an 8 amp and 10 amp circuit breaker?
   / TC-33 Blowing the #2 Fuse #27
Beginning to sound like a bad relay that has lost some isolation..
Soundguy
   / TC-33 Blowing the #2 Fuse #28
Did you mean insulation Soundguy? Now I am confused.......
   / TC-33 Blowing the #2 Fuse #30
Jim it looks to me like Waytek also carries the Contra switches. Those are made by Carlton Switch who supplies NH with their switches. Your rabbit/turtle switch is a Contra XII series
Good prices on electrical components. I ordered up one of their hard printed catalogs.
