I've done the parking brake trick a few times. Start plowing down the row, and wonder why the tractor is lugging harder than normal - look down and realize the parking brake is still on. :ashamed:
Pulled the baler out of the barn last year, tried to swing a real hard left down the hill to make the cut in the trees - snapped the top part of the tongue right off. Fixed that with a little bit of redneck ingenuity. Baler rides an inch higher on the tractor now.:ashamed:
Backing the combine out of the barn the first year I had it running again. It was only the 6th time I had done this....it was almost pitch dark, had been a long day, and I was tired.....got a little too close to the barn where the side of the door frame juts out. Caught a board with a pulley wheel on the side of the header - the board gave way, but not before it snapped the casting that held the pulley in place. Fortunately my good friend figured out how to weld old cast....still have a c-clamp helping support it on the side of the combine though...:ashamed:
Had a coulter facing the wrong way on the plow when I lowered it back into the ground. It caught against the drawbar on the tractor and snapped the coulter right off. Been using the plow without that one coulter for going on 3 years now. Fortunately that was the least needed one to help keep the shares clean.:ashamed:
Trying to get a 7-acre field planted with winter wheat at night before the rain hit. While pulling the seed drill across the creek crossing, it got too close to the sharp-cut bank on one side, and ripped the valve stem out of the tire. I didn't have time to fix the tire and still get planted, so I took my corners carefully with one flat, and got the field planted that night - finished 20 min before the rain started. The one side of the drill dropped in seed just a bit heavier than the other side, but I got it done. Threw a tube in that tire a few days later. :thumbsup:
I've got more stories, but these are just a few good ones.
