Ok...now I did it...went to put the new exhaust elbow on because old one was cracked all around. Got it off and put the new one one. Someone had converted the exhaust to a vertical. The muffler and stack pipe were fused together, so took off the bracket from the block, and took the assembly off. Got the broken part of the elbow off the muffler and new elbow bolted on the manifold. Went to put the muffler/stack assembly on and would not go on elbow. Inlet on muffler was deformed. Tried to straighten it out the inlet and flare it a bit. Got it started on elbow, but could not get the stack to clear the headlight. About 2" shy of being fully seated on elbow. Thought, "no problem, I can tap it on with a little help from a hammer".
You know where this is going...
Now I need a new manifold. Gonna get a new muffler also.
Got any places you guys recommend to buy parts? There a quite a few, but though I would see what you guys usually use for a source.
Anything I should be aware of when replacing the manifold? I know to use brass nuts, but anything else?
Thanks!
Chris
