Tire Pressure for Rears with Ballast
   / Tire Pressure for Rears with Ballast #1
Gryz
Yanmar SA424
I have a compact Yanmar SA424 and was wondering what the proper PSI is for the rear tires when they are loaded with ballast? I have searched and cannot find a definitive answer. I'm sure it depends on a few factors, so I could give more details if needed.
   / Tire Pressure for Rears with Ballast #2
When I received my Kioti from the dealer they had inflated the loaded tires to the recommended PSI listed in the manual.
Thank you. The manual says 30PSI for my R4 tires, which seems like a lot considering almost 75% of the volume is now filled with ballast.
   / Tire Pressure for Rears with Ballast #6
If you used a ballast box have it mounted. Get your tires wet. Drive across dry concrete. Adjust tire pressure to just get full contact.
   / Tire Pressure for Rears with Ballast #7
30 PSI for a rear tire seems high but possible. I think mine is around 15 rear and 25 front. I run the rears softer and have never had issue with bead slip.
   / Tire Pressure for Rears with Ballast #8
I have R-4's and run 40 PSI front and 15 PSI rear with liquid ballast
I have R-4's and run 35 PSI front and 15 PSI rear with liquid ballast
This is about what I assumed would be suggested. Guess I will start here and see how it goes.
   / Tire Pressure for Rears with Ballast #10
I run my front R4's at max sidewall pressure (45 in my case) because I use the loader a lot. Filled rears are 15 psi.
