3RRL
Super Member
- Joined
- Oct 20, 2005
- Messages
- 6,825
- Tractor
- 55HP 4WD KAMA 554 and 4 x 4 Jinma 284
Robert,
With those symptoms, your starter and solenoid are probably alright.
I'll bet it's a loose connection or bad ground somewhere. Often, a loose connection jiggles around enough to allow starting when it makes good contact. But it also builds up a layer of oxidation or crud as it arcs, which makes it no good until the next jiggle to a fresh connection. When it does that, your TN won't start and it causes a lot of resistance possibly causing the fuse to blow. I would check through your electrical connections, clean and tighten them one at a time.
Rob-
Rob-
