That is a nifty setup you got there. DO you have a bunch of the built for easy moving ans storage? How much does it hold? I have been pondering build something similar to easily move my wood around instead of restacking it all the time.
I just got the wood stove this year, so I'm building these as I go. I got a bunch of free pallets, and have been using pressure treated 2x4's for the sides, and salvaged slats from broken pallets for the top part that ties the sides together (saves me a $3 PT 2x4 per pallet).
They're 40" side (width of the pallets), and 4' tall. So, they hold a little less than 1/2 face cord. This is about all my little B7100 can lift with it's paltry 400lb rear lift capacity. I have a front fork as well, but I use the rear carry all, as putting this load on the back tires is much easier on the lawn, and steering. I would estimate the weight of the pallet loaded with freshly-split still-green oak to be about 500lbs, bassed on the fact the 3PH struggles to pick it up, and it is OK with my 400+ lb box blade. I do need to adjust the 3PH relief valve, as it is only allowing 1500PSI, where the system is rated for 1700 PSI (which would give about another 50lbs lift capability).
The hydraulic top-link is key to making this work, as my ground is uneven, and I need tilt capability to level the fork to slide out of the pallet.
As you stated, I built these to eliminate the need to restack, and handle each piece multiple times (load on the trailer, remove from trailer and stack). Once dried, these will get moved to a covered location, and replaced with more freshly split wood.
Regards,
Jay
