Egon
Epic Contributor
this may be a stupid question, I know there is off road diesel but is there off road gas
In some of the areas I am familiar with there is.
this may be a stupid question, I know there is off road diesel but is there off road gas?
Okey Dokey.
Say, this topic is about played out. Let's start up (again) about HST vs gear. Or is it time for 2wd vs 4wd? I forget where we are in the lively discussion rotation...
jb
Who the heck wears out a carb????
Avgas and marina gas. Trouble is, you pay more, not less.
So what makes them wear out, if this one wore out. perhaps it was the wrong carb on this one. Carbs are not made from the strongest materials.
The torque issue that causes a diesel to compete favorably with a gas engine of equal horse power is that there is more area under the torque curve. This means that the torque of a diesel engine is flatter, maintaining a high level over a broader rpm range. This, in turn, means that the diesel produces more hp than the gasoline engine at all parts of the rpm range except at the rated rpm of each engine. At that point only, does the gasoline engine produce the same HP as the diesel. This is a demonstration of tractability - the diesel HP is easier to use. It absolutely cannot do more than a gasser of same HP if the gas engine can be maintained at an appropriate rpm. This is almost impossible with a gear transmission, but becomes more likely when comparing the use of automatic transmissions on each, and can be identical with both transmitting their identical peak HP thru HSTs where "gearing" can be varied infinitely. A gasoline engine having greater horsepower will always outperform a lesser HP diesel if the transmission/operator combination is sensitive enuf to use the narrower range where the gas engine produces its peak --not very difficult with an HST.I definitely like diesels: can do most jobs with less hp than gas because of big torque of the diesel....[snip]
In a 3,000# car, for instance, a 100 hp diesel is great; whereas, you need about a 125-140 hp gas engine one for the same performance.
Ralph
