Like most of you guys I had to learn from experience. I started off with a 2320, MMM, BH and blower. What a PITA, Steve is right 8 in 1 sucks!
I just went to a bigger tractor 3320 with a 445 ztrac. Much better and we're using a 990 for implements so the 3320 will be a dedicated TLB if it ever gets here!
I never owned a Shopsmith, I could see the problems and all the set ups just to get through one project. I use a Delta saw, dedicated band saws and planers.
For metal I run a Maximat 11 lathe (english) and a Maximat V10P (metric) as a dedicated milling machine. It's the cats meow. My Miller 210 has 2 guns and two tanks so I can just pick up one gun for steel and anotheer for aluminum which saves me the pain of switching spools for every project. Besides you really can't run aluminum without a spool gun unless you like jammed wire! If you do a lot of different jobs like I do there is no comparison to a dedicated machine.
Even for my electronics work I use dedicated Agilent equipment. The all in ones suck there too!
I know lots of guys can't afford to go this route and I suggest you go with the a very good machine for your major tasks and low priced used that you may have to do a little work on for the rest of the machines. You can gradually work up to better machines for the low priced used ones over time.
The thing about maintaining machines is that you'll do more maint. over a longer time with dedicated machines. You won't use your tractor for mowing so you'll extend the time between oil changes for example.
The other thing is that if you're using lots of machines it's best to be able to do your own work to some degree. Ok maybe not like me who works down to the component level and rebuilds boxes when he has to, but at least be able to do all your scheduled oil and filter changes and maybe an axel bearing or seal if one goes bad.
Steve, I know the SCMI's, sweet saws!
Rob
Rob
