Matt_Jr
Platinum Member
I love threads that involve theory.
You are all correct. Mostly. Vacuum is an absense of pressure. Scientists at NASA are still trying to make perfect vacuums to test space suits. They can't yet, but come pretty close by our standards using very strong pumps both piston and vein. A perfect vacuum is theorized to exist at 30 inches of mercury. No pump in the world is strong enough to do that. The most effecient running gasoline engines (not including high performance engines) at sea level will have a reading of approximately 18"hg (hg is mercury) at idle. If one was to connect a 1 inch squared tube to the manifold of their gas engine while idling the atmospheric pressure surrounding the bucket of mercury would push the mercury up the tube 18". If this same procedure was done with a diesel engine the mercury may not be pushed up the tube at all. The reason is that there is no throttle plate on a diesel. There is on a gas engine. If you put a rag in front of the throttle body atmospheric pressure will push the rag into the throttle. Although the rag is pushed into the engine by atmospheric pressure we usually describe the rag as being sucked into it. Go ahead guys, let me have it.
As for the plane on a conveyor belt. Once it leaves ground effects will it fall back to the ground.. I mean.. back on the conveyor belt?
