jimgerken
Veteran Member
Anybody with a 3x20 series JD run a PTO genny that can speak to the auto throttle to keep RPM adjustments?
really no one has the Voltmaster genny? Price looks good, American Made, and looks of high quality.
I like all the bells and whistles on the Harbor Freight 15KW but I am Leary of all that stuff failing since it is Harbor Freight.
Then there is the debate of Brushless vs Brush? I only plan on using it for emergencies currently and wonder. If it would be a big deal.
I have a JD 3720 and run a 15Kw PTO generator. It is pretty much "set and forget" once everything is warmed up. Even the well submersible pump kicking on will not significantly change the frequency. I believe the tractor's governer is dealer-serviceable to provide better speed control if you have trouble. Pretty sure I remember someone adding that to a Generator thread a couple years ago.
Mine's a Power Connection set: The Power Connection, Inc. - Generator solutions for home and agriculture
I have no comment on the brushes issue, except that most of what you see today for sale has no brushes, instead they use slip rings like your car alternator to energize the rotor windings.
