bota7800
Also, I am not a fan of WD40 either except to actually "WD". I was referring to labeled penetrating oil, thin dark and smelly.
caddelma said:I am wondering if the wax does not act like water when it freezes...i.e. once the wax returns to a solid state it expands, much like ice does when it freezes. I am sure we have all dealt with the effects of water expanding when it freezes...busted water lines etc. If water exerts enough force to bulge/crack aluminum that is 1/8-inch thick, maybe the wax is able to exert enough "force" to break the rust bond of the threads.
Even if my theory is a bunch of hogwash, the wax certainly helps as a lubricant.
CurlyDave said:Wax, like most substances actually contracts when it freezes.
Water is the oddball, expanding as it freezes, but it is so common it tends to make us think it is "normal".
ulbhunter said:My question is how hot must the metal be for the wax to work into rusted threads?
I have something of a unique problem. I inherited (in a pile of junk) a old oxygen cylinder that was stamped as tested in 1949,1951, and 1956. This tank has a protection cap that is rusted shut. I was able to work my fingers into the holes on the cap and turn the valve a little. The tank is still pressurized.
On rusted items I would normally use penetrating oil to break free the threads or use my torch to break free the threads using heat. Oil and oxygen is an explosion waiting to happen and I am not going to get a torch anywhere near the tank until I have removed the valve completely and I am positive that no pressure is present.
My plan of attack is in order of preference (1) use a friend and his set of extremely large pipe wrenches and chain wrench. (2) Use either a porta-band saw or an air powered small die grinder with a small cut off wheel to slice the protective cap (being careful not to get the cap to hot) to a point where I am able to remove the cap. or (3) place a shape charge on the tank and bury the tank 8'-10' underground and then from a safe distance and behind protection detonate the shape charge and force pierce the tank
(yes, I am trained and authorized to use explosivies).
Is is posssible to heat the cap/threads enough with a simple electric heat gun that the wax would wick ?
61flattop said:If I remember right... wd-40 was not originally designed as a penetrating oil but as a water/ moisture remover. As far as a penetrating oil, nothing beats PB blaster. I can not stand the smell of that junk but it works. I will have to try this wax bit though. Sounds interesting and I have never tried it.
Soundguy said:Wd-40 is a pretty poor unstickum lubricant.. plus it has a half life of about 5 minutes before it evaporates. I have better luck with a mix of kerosene and atf fluid mix, in a squirt bottle.
soundguy
