mike69440
Elite Member
- Joined
- Jun 2, 2005
- Messages
- 3,089
- Location
- Central NH (God's Country)
- Tractor
- 1984 Kubota B7200D (Sold 2015,) 2005 L39 Kubota, 2006 RTV 900 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle
This weekend I used my new L39 TLB to remove a medium small size stump with the BH and used the TL 1000 FEL to grade the driveway and move some rocks and dirt.
My other tractor is a tiny 1983 B7200. I have about 500 Lbs of steel plate attached to the loader frame and the relief valve on the loader screwed in to give itch loader more capacity. The B7200 weighs about 2400 Lbs with loader ballasted tires and small weight box. It has a 4 Ft bucket.
I have operated a few other tractors like a 30 HP Kubota with as I remember a 723 Loader and an NH TC29 with Loader.
The L39 Loader performance seems very weak for the size of the bucket. I was very surprised and disappointed considering other peoples reports on the L39 and how Kubota touts the loader performance. The TL1000 Loader seemed very weak in its ability to curl, especially back curl. I am used to being able to move material and large rocks by backdraging. The L39 was maybe only at most 50% stronger overall than my little B7200 in back dragging, If I had more than 6 or 8" of dirt, the bucket would just roll forward when I back dragged. I found it difficult to drag a rock only marginally larger than what I would move with my little B7200.
The Loader will pick up the front end of the L39, but the Loader is stronger in the loader boom cylinders than the bucket cylinders. Does the boom cylinders have a separate relief valve from the bucket cylinders?
Other than being Limp wristed, the loader performance is normal from a control and speed standpoint.
The specs say the loader should be allot stronger than what I have experienced. The curl force on the bucket is supposed to be 5,000 Lbs. Mine seems like about maybe 2000 Lbs.
I also question the loader lift capacity. Although the TL1000 seems to be okay in this area, it is only about the same as the NH or the larger Kubota, I operated, which are Agricultural machines and not up to what I would expect from this highly touted TLB.
The bucket got stuck lifting a load of stone base from a soft pile.
If I used the backhoe and put the bucket front edge to bite the ground along with deploying the stabilizers, the loader would move around and not hold position when pulling with the BH.
I have read where others comment how strong the loader is. In one instance speaking of breaking chains with the loader and being able to lift the back of the L39 with BH attached off the ground with the FEL.
I can put the bucket edge under the edge of large rock and try lifting, neither the tractor or rock move. If I do the same with my weighted down B7200, one rear wheel will start to lift.
Before I bring this up with my dealer, I would appreciate others confirming that the loader performance I described is not right.
Thanks, Mike69440
Thanks, Mike69440
