jonyyuma
Elite Member
- Joined
- Sep 14, 2010
- Messages
- 2,947
- Location
- 35 miles North of Memphis,TN
- Tractor
- kubota L3000dt, ford 8n1952
It looks like wax, because it IS wax (paraffin primarily) .
The fact that it started up again after 1/2 hour indicates that there was probably some heat soak going on and it melted back into solution.
Mercedes USED TO suggest up to 30% gasoline as a winter "blend" in situations where winter blend isn't available - though I think this might have been as an emergency measure only.
I sometimes consider a 10% to 20% mix when the temperature drops suddenly and I know I still have summer fuel in the tank - then I check and top up with the local seasonal blend.
Gasoline is not recommended here in any diesel fuel, it makes it chemically unstable. Kerosene is okay to mix. Yes, there is paraffin in diesel, it has always been there.. It is left there for power, if removed the power ratio suffers a lot.
