CinderSchnauzer
Veteran Member
- Joined
- Apr 26, 2006
- Messages
- 1,419
The biggest Marina in my area and in Cincy where I used to live have pits filled with 1000's of gallons of anti-freeze. They look like loading docks at a freight depo. They simply back the the trailer in far enough to submerge the water pick-up on the engine, fire it up and allow it to run for aprox 10 minutes to come up to temp then shut it down. It takes about 5 gallons to fill the average V8 inboard engine. Doing this puts lake water into the mix each time they start a engine so they simply do 10 boats or so the roll over a 55 gallon drum of anti-freeze and dump it in. Like I said these pits hold a couple thousand gallons so the mix stays pretty consistent at 50/50 and is checked daily.
Chris
There was also a time when boats discharged raw sewage into the rivers and Great Lakes. Many thought that was OK. Dumping 1,000's of gallons of antifreeze into the lake falls into the same category.
Just because it is being done does not make it right.
