clemsonfor
Super Member
lol yea i spelled SVO out . if i can grow it and dont need to convert it to biodiesel .. why would I it adds only more time and expense, i never got this..
i know you can buy a fancy European system that works on almost anything with a single or separate tank better pump and injectors heaters filters valves lines etc... also there are some "older" or simpler engines in cars, atleast, that are more tolerant of straight veggie oil and some (newer and complex) cars that will have to be overhauled. unfortunately my expertise on tractors is riding with grampa a few lol years back. so i would figure i would ask here since i would guess yall know much more of tractors.
adding one last, older tractors are the main search i am doing as i can not justify 20-500 thou on a small 55 acre. so if anyone knows of a better place to look or know of a old or more reasonable price small(bigger than a riding mower though) if i can pick up a older 8n or massey and do the maintence due filters lines lubes that will be done anyway that will work with straight veggie.
ps i read in various places (SOME) yamars and kubota have been used not sure of the modifcations, as it was only a mentioning
To start off i will say i have an old yanmar deisel, i also have never even run 5% bio in it, so i have no personal experience.
First thing, the 8n never came in a deisel, for that matter neither did the 2n or 9n. So unless you convert it to a deisel engine forget bio in one of the older ford N tractors. The later 2000's and 3000's had deisels in them. I think all the 01 seeries also were only gas (these were the fords thru the late 40s and 50s, like the 601 and 801..).
Back to deisel. A member here (his name is California) on the yanmar board was using 100% biodeisel in his yanmar. It ran great once going and warm, he said it did not like to start well in the cold. Well that was for a few years then it would run bad and not really start and he found out one of his injectors was trashed and the other not much better. He ended up having to pull them and replace them, i think it may have only cost him about $120/oer injector due to the simplicity of those tractors but still not worth the little bit of savings on a small amout of fuel these size tractors use. He also noted the maintence in the book says to check/clean injectors every x hours or something, his thoughts were that with bio you would need to do this 4x more often.
Just what its worth.
