IslandTractor
Super Star Member
- Joined
- Sep 15, 2005
- Messages
- 17,101
- Location
- Prudence Island, RI
- Tractor
- 2007 Kioti DK40se HST, Woods BH
Going back to the original question, what is the SMALLEST tractor? That depends more on what you intend to do with it than the overall acreage I'd say. Of the implements you mention the hay spear is the most concerning as that implies lifting bales but you don't tell us what size bale. Some bales weigh over a ton and obviously would require a 40+hp tractor/FEL to handle. Other bales can be lifted by a man. You also don't tell us whether you want small because of the desire for a physically small tractor or whether you are just using small to mean low cost. I'm guessing the latter.
I have experience with a tough little 21hp tractor (Kioti CK20) with a pretty powerful loader for its size (lift at pivot pins 1170lbs) which was extremely capable at all sorts of tasks when fitted with appropriate sized implements. If you are looking for the SMALLEST practical general purpose tractor I'd look at that or the equivalent Mahindra. The new line of Kubota B series in the mid 20 hp range would also be a consideration. None of these sub 30hp tractors is going to plow 100 acres or lift one ton bales but they would more than double what you were able to do with your old 15hp tractor for sure. They are not sub CUTs and have good ground clearance and with a few exceptions really can do pretty much all the types of tasks the bigger tractors can do so long as you can accept the limitations of smaller sized implements.
My other personal experience is with a Kioti DK40se which is twice the horsepower of the CK20 and more than twice the lift capacity. I'm sure it could handle the bigger round bales. I do mowing, brush clearing, and general utility work on about 25-30 acres with the DK40se and haven't once wished for a bigger machine (well maybe once or twice but then I wanted a bigger bulldozer.). It is also a darn good value and I believe can still be had for under 20K with loader. I got mine for under 18K in 2007 right after they came out. Nothing in the tractor world touched it for value/price performance at that time. It is not a barebones machine either and comes standard with suspension seat, electrohydraulic PTO and 4WD, rear remote, draft control etc as well as a four year warranty. Pretty hard to top as a value tractor especially with zero percent financing.
