Where is the north star or brightest star in sky?
   / Where is the north star or brightest star in sky? #11
Remember to keep the planets separated from the stars. Planets are usually the brightest.:D :D
   / Where is the north star or brightest star in sky? #12
MrJimi is having some plugin problems with StarCalc.
Here is where the plugins should be.
Cool, how did ya do that? print screen feature?
Mine shows a little dif view? does that make a dif?
   / Where is the north star or brightest star in sky? #14
The time and location function may not work automatically. If things don't look correct, go into the Parameters menu and choose Options. Click the Location tab. Enter your location's latitude and longitude (easily googled) and the time zone and click O.K.
   / Where is the north star or brightest star in sky? #15
when you get everything set the way you want it, you should choose the View menu and tehn choose Save State. Be sure to check the Latitude, Longitude and Time zone box.
then, the next time you run StarCalc, choose the view menu and restor state, then choose your file. Then hit the third clock down on the left for NOW time and it should take you to the current time.
   / Where is the north star or brightest star in sky? #16
With the window open that you want to copy, hold the ALT key down and press the PRINT SCRN key. That captures the open winow to the clipboard. Then open up an image editing program like Paint Shop or Photoshop and paste it in. Then save it as a JPEG.
This is what I have? I still don't think I put them in the right place
Sorry about that, it will be better next time, I'm new at this
   / Where is the north star or brightest star in sky? #18
That's the correct place for the plugins. (in that second attachment that you posted).
This is what I have in the services menu?
   / Where is the north star or brightest star in sky? #20
One sure fire way to tell if it is a planet or star.....star's twinkle, planets don't.
