orangetree
Small TLB here with a few implements that have bearings such as a pto snowblower, pto chipper. I've just used the same grease all around until now - but it's been nagging me and I doubt my lithium/moly grease correct for the "fast" or "spinning" interfaces.
For the loader, BH, grapple, etc - the lithium-complex moly fortified grease does seem ideal. Note, I was jumping around brands as I could pick it up on the drive up, such as Valvoline Moly-Fortified Gray/Lithium Full Synthetic. I've realized this is stupid and have 'standardized' on, and now stock, John Deere HD Moly Grease Case TY6333 (picked the Deere because it seems the most consistently widely available online & in my area). I believe this (the Deere 3% moly lithium-complex grease) is the "optimal" choice here for these (A) low-speed/temp (B) high-pressure and (C) sliding surfaces.
On the bearings, though, hope I haven't damaged them, or caused myself a bunch of work to strip & re-pack . Using these two as an example:
Thanks!
- snowblower 1st stage shaft bearings, chipper feed bearings: it's a bearing (eg not a sliding interface where Moly excels). But it's relatively low RPM so practical difference is probably really low(?).
- snowblower 2nd stage is to be 500 or 1000rpm (eg roughly car wheel bearing speed), and are bearings not sliding surfaces
- pto shaft u-joints: bushings not bearings (moly is good for sliding) - but relatively fast. Potentially too hot for lithium/moly to be ideal?
- Slow + Sliding (bushings in loader pins, etc)
- Fast + Sliding (engine-speed U-joint bushings such as PTO)
- Slow + rotating (slow (10's or RPM) ball/roller bearings - geared down shafts)
- Fast + rotating (engine-speed ball/roller bearings)
Thanks!
