plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,055
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I need to choose a brush hog type mower for 12 acres of mostly open pasture. Mostly weeds, don't notice any saplings, up to 2-3 ft high. Light to moderate slope. There is one draw/ravine where water drains (winter.) The pasture is lined with large trees, and it is desired to do some amount of mowing between them. I can mow up/down where slope is greater, except one area above a pond. In that area it might be advisable to "back down" and mow up. Just guessing about that. The Massey 1758 cab model it will connect to has 44.5 pto. Weight is a little over 5,000 lbs.
I'm not sure about 3pt vs pull type. It seems a 3pt is more maneuverable, but the pull type cuts a wider path with less stress on the tractor? I will have a loader to counterbalance a 3pt model, and the rear tires are loaded. When mowing with my 4' brush hog, I have sometimes raised it up, backed into a tight area, lowered it, and drove out. I could see myself doing this where the trees line the pasture, where it is also fenced. I'm guessing the pull type is "forward only?"
For comparison, Woods offers each that would fit my tractor:
MDS8.30 3 point, 96" cut, 45-100 pto, 1,200 lb
DS120 pull type, 120" cut, min 40hp, dual wheels, 2,100 lb
For this property, do you think you would be happier with a 120" pull type, or 96" 3 point mount model?
