CI-4 diesel oils are readily available from many suppliers, Delo 400 is still made in CI-4. I called Chevron this week about this question, because I have a new ZD331 myself with 4 hours on it. I also have a JD Gator, and want to continue using 10W/30 oil in the Gator, and also the Kubota mower. My manual on the Kubota allows for 10W/30, and the Delo 400 is plenty capable of lubricating that little 31 HP. The tech rep also mentioned that it was a concern over people buying high sulfur diesel, that CJ-4 is a lower TBN product, not recommended for fuel like that. I quit driving tankers 3 years ago, but I believe that high sulfur diesel is not able to be loaded any more at refineries---(could be wrong but don't think so) TBN is the Rolaids of the engine oil, it neutralizes sulfuric acid so that wear and corrosion arn't lethal to the engine. Low sulfer fuels have 15 parts per million sulfur, negligible, and a lower TBN oil can be used. I plan to use Chevron Delo 400 LE in 10W/30 in my ZD331, and you might have to buy that at a Chevron Distibutors place, not at Wal-Mart most likely. Chevrons # is 1-800 LUBE-TEK.
