twes36
Just an observation. If it can be documented that the damage is due to a lightening strike, it is probably covered under your homeowner's policy. I would file a claim if there was significant damage.
I would start by verifying that the compressor is indeed bad. I've seen too many techs that condemn a unit for the same reason, only to find that the compressor is OK and another issue kept it from running. Check each terminal at the compressor, with all wires removed, to ground with a ohmmeter and also from each terminal to each other. A lightning strike often burns up the capacitor, but leaves the compressor undamaged. $25 or $2500...your choice :2cents:
