buickanddeere
Super Member
jd110
buickanddeere mentioned a 3 cyl inter-cooled engine. Do you know if JD built that particular engine? I briefly searched but couldn't find a tractor model with one.
Thanks,Jim
Industrial
jd110
Thanks,Jim
AKfish
Although I was chastised by a certain Canadian for starting this thread I think it has turned out to have some very valuable information. I'm with you on the larger cube engines. I liked to see if the 276 cid Tier lV has the same lugging ability as my 4255 with a 466 cid
Industrial
Verticaltrx
What testing source do you use to obtain the info on the Kubota engine? What in your opinion are the reasons a Kubota engine falls behind the JD in the tests?
The Nebraska tractor test lab has alot of that info... gotta pay to see the graphs for torque curve/hp, though. (Dagnabbit!!) Be interesting to note how "peaky" some engines are versus another.
AKfish
Verticaltrx
I couldn't find a Nebraska test on a Kubota tractor nor do I think Kubota's are tested at Nebraska.
