Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    Veteran Member Runner's Avatar
    Join Date
    May 2007
    Posts
    1,666
    Missouri
    John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
    Default Welding Table
    When I mentioned this project in another thread, someone indicated some interest in seeing how it came out, so here it is.
    This project is tractor-related in a couple of ways. First, it will be used to build tractor attachments. Second, I used my boom pole to set the top on the table.
    The table frame is constructed of 2 inch and 1 1/2 inch square tubing. The top is a 53 x 60 inch piece of 3/8 inch checker plate steel that the previous owner left in my barn (thank you, sir). The shelves are 1/8 inch sheet steel.
    I used 3 inch cast iron casters and a couple of HF scissors jacks for brakes. Used the original jack handles, but had to shorten them up a bit for clearance.
    This was my very first project using my new Miller 211 MIG welder and I had a ball with it.
    Attached Thumbnails Attached Thumbnails Welding Table-img_1762b.jpg   Welding Table-img_1777b.jpg   Welding Table-img_1792b.jpg
    Runner
  2. #2
    Super Member JB4310's Avatar
    Join Date
    Feb 2005
    Posts
    5,645
    Central CT
    J.D. 4310 E-hydro
    Default Re: Welding Table
    Came out great, and you can use it for any work table needs not just welding.
    JB.
    JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 48", 61"HD & 73" high volume bucket.
    FORD 1700; 2 WD, 2600 hrs.
    JD 320; Hydra lift, 48" deck and 48" snow blade.
    2007 Dodge Ram 3500, Cummins 6.7L, Aisin 6 speed, 9ft utility body.
  3. #3
    Join Date
    Dec 2009
    Posts
    1,000
    Looks nice. I built one similar to what you built but, it is alot narrower and lighter built top than yours and use it for so many more things than a welding table.
  4. #4
    Join Date
    Sep 2009
    Posts
    563
    Fallbrook,Ca
    Satoh Beaver,Buck,Iseki Farmbos
    Quote Originally Posted by Runner View Post
    Great project,
    I'm thinking of doing something similar.
    One thing I have done with most of my stuff is to make it palletized . Instead of adding casters, I just make a provision of pallet forks. Just roll whatever you want out, use it and then roll it back for storage.Also you don't have to worry about stuff rolling around while you're working on it.
    You also don't have to buy casters! They don't call me El Cheapo for nothing.
  5. #5
    Platinum Member Army grunt's Avatar
    Join Date
    Dec 2009
    Posts
    775
    Georga
    TC 30 Newholland
    Great looking table when can i pick it up? are you going to build one for yourself?
    Grunt
    "Be who you are, say what you will, those that matter wont mind, those that mind don't matter".
  6. #6
    Gold Member actionaj's Avatar
    Join Date
    Oct 2007
    Posts
    427
    Southern Illinois
    BX2350
    Nice job, You wont have to worrie about that one turning over if it did look out.
    BX2350
    FEL, RCK54 MMM, 4' Farm Star BB, 5' Farm Star RB, 5' Rake
  7. #7
    Join Date
    May 2007
    Posts
    1,666
    Missouri
    "Nice job, You wont have to worrie about that one turning over if it did look out."
    I estimate the top weight to be around 325 lbs and the total around 500 lbs, minus anything stored on it. So, I definitely wouldn't want to be under it if it fell over.
    I had a lot of fun getting that sheet steel into the upper shelf. The diagonal between the shelf and the top was not as long as the shelf width, so I had to bend it into a "U" shape to get it in there. Probably was an easier way to do it, but I wasn't smart enough to figure it out....
    Maybe should have just left out one of the tubes and welded it in afterwards.
    Runner
  8. #8
    Veteran Member weldingisfun's Avatar
    Join Date
    Dec 2006
    Posts
    1,453
    West Bell County, Texas
    Mahindra 4500 4WD w/FEL, and Scotts S2048 lawn tractor
    Great looking project! Nothing fancy, just a good solid welding table.
    One day I'll get around to building one for myself.
  9. #9
    Join Date
    May 2007
    Posts
    1,666
    Missouri
    It is fancy compared to my old one....
    Runner
  10. #10
    Veteran Member deepNdirt's Avatar
    Join Date
    Sep 2009
    Posts
    1,926
    Nth East Ga, USA
    yanmar YM-1700
    It is Nice and well built for sure, I'm doing a lot more welding these day and been thinking of building one, I know we all have tractors to help us with lifting heavy things onto the table But have you thought of putting a swivel boom on one corner? might have to counterweight the table,
    one of my my neighbors is a skilled welder and has setup his shop with tables and lifting booms, actually last time I was over there he had installed a electric overhead boom, he's getting hi-tech he can afford to be Hi-tech because he charges enough for his work 25-35 bucks a pop! for 5-10 minutes of welding time,
    Never judge a man until you've walked a day in his shoes,
Similar Threads
  1. begining welding
    By greenthumb in forum Welding
    Last Post: 01-11-2011, 10:25 PM
  2. New Welding/Shop Table Ideas
    By MRCONCDID in forum Build-It Yourself
    Last Post: 01-13-2010, 01:46 PM
  3. feedback on HF AD welding helmet
    By Soundguy in forum Welding
    Last Post: 10-09-2006, 04:31 PM
  4. Replies: 0
    Last Post: 12-07-2004, 07:45 AM
  5. Patronizing local welding supply shops
    By Spencer in forum Welding
    Last Post: 01-27-2003, 12:43 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
