atv flail mower
   / atv flail mower #1
yukon1975
atv flail mower
Hello all,
New to the forum, Looking to see if people are interested in self powered flail mowers to pull behind atv's or tractors. Mows very well. Cuts 5 foot plus tall grass and shrubs and 1.5-2 inch saplings. DSCN8571.jpg
   / atv flail mower #2
NIce
If I didn't have a tractor, I would be interested in one...
How much?
   / atv flail mower #3
Depending on price etc, I would. I have a tree farm that something like this to pull behind a RTV would be a nice addition.
   / atv flail mower #4
How about some more data on the machine. What about a web site, or something.
   / atv flail mower
powered flail mower
will cut and mulch grass, brush and saplings 1.5-2.5 inches in diameter.
Rear roller to protect flails
Easy height adjustment with the turn of a handle
2 inch ball hitch
Weight:280 Kgs
Cutting width:48 inches
Efficiency:2500~ 6500m イ /h
Engine Model: Lifan 389, 13hp gas engine
Engine type: 4-stroke, 25 inclined, single cylinder with Air-cooled
BorexStroke (mm/inch): 88x64/3.46x2.52
Displacement (ml):389
Compression ratio:8.0:1
Max. output (HP/rpm):13.0/3600
Max. torque (N.m/rpm):19/2500
lgnition system:Non-contact transistorized ignition (T.C.I.)
Start mode Recoil and hand-operated/Electric start
Air cleaner Semi-dry, oil bath, dual, double silent and cyclone type
Fuel tank capacity (L/gal):6.5/1.7
Fuel consumption(g/HP-hour):290
Engine oil capacity (L/gal):1.1/0.29
Dimensions(LラWラH) (mm/inch):510x460x450/20.1x18.1x17.7
Will try to post video soon.
   / atv flail mower #6
count me as interested, any clue as to the price?
   / atv flail mower #7
Hello all,
New to the forum, Looking to see if people are interested in self powered flail mowers to pull behind atv's or tractors. Mows very well. Cuts 5 foot plus tall grass and shrubs and 1.5-2 inch saplings. View attachment 229667
Is this like a FREE COMPANY AD or are you trying to sell yours or what?
   / atv flail mower
the price would be around 2200.00+shipping, about 2400 total with shipping. I bought two, using one and looking to sell the other. I can only get a minimum of 5 at a time:eek:, the original shipment was for a product trial, and had to order at least 2, so was trying to find out if people were interested in these mowers.
   / atv flail mower #9
Just my opinion:
I can’t see how anyone could justify that price, when rotary cutters are so common and can be had for less than $1k.
No offense, but I don’t believe that it can cut trees 1.5-2” in diameter. At least, not without getting very beat up.
   / atv flail mower
Just my opinion:
I can稚 see how anyone could justify that price, when rotary cutters are so common and can be had for less than $1k.
No offense, but I don稚 believe that it can cut trees 1.5-2 in diameter. At least, not without getting very beat up.
I'll post a video soon, and yes it can cut trees 1.5 -2 inches and not get beat up, I would not recommend going through and cutting a forest of 2 inch saplings down, that is not what any mower is intended for. It has great ground clearance when needed, and this can also cut your lawn to a finish cut and bush hog. Great when you have more than 2 acres to mow, either to a finish cut or rough cut. I could probably get the price down a bit with larger orders, but probably only down to about 2k+shipping.
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2021 Bobcat S740 (A50123)
2021 Bobcat S740...
(2) UNUSED 3500# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 3500#...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2017 CATERPILLAR 307E2 EXCAVATOR (A51246)
2017 CATERPILLAR...
2014 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2014 Great Dane...
