Mahindra 2415-1 Reviews
3.00 star(s)
1IVBob
2415-1 Mahindra
Mahindra 2415G Pinion Bearing Problems
Model Year: 2008
A great little tractor, 'till it breaks down. An obvious design flaw in the rear differential. The same problem just appeared for the third(!!!) time. At about 150 hr. intervals the tractor locks up. Always while in low range. Apparently the pinion bearing gets pushed through the housing which is part of the rear differential case. The first time Mahindra fixed it under warranty at 140 hrs. Then, at 293 hours (153 hrs. later), it reoccurred. Warranty period was up but the wonderful owner of Rogue Valley Tractor in Medford, Oregon ate the costs and repaired it this time with a re-engineered case made of steel instead of aluminum. This was not Mahindra trying to do the right thing; they stonewalled for months. I was optimistic this would solve the issue. Well guess what? At 446 hrs., exactly 153 hrs. after that repair with upgraded parts, the same problem has, like a bad dream, returned once more. Now I am trying to find a repair manual since I don't expect Mahindra to become magnanimous at this point in the game and I can't afford the thousands it will cost me to take it in for repairs. Maybe I can find a machinist that has a problem solving ability to beef up the obvious weak link in the drive train of this tractor.
Pros: Good power, suitable for a tall individual.
Cons: Recurring drivetrain issues, factory rep unresponsive.
5.00 star(s)
boxygen
2415-1 Mahindra
2415 HST TLB
Model Year: 0
Its been an excellent tractor. I built my own septic system with it, along with all the groundwork for a new garage. I rake hay with it, and pull a fully loaded hay trailer. I'm convinced that its the most tractor you can buy for the money. 5' bush hog is no problem. It also has no trouble at all with a 6' snowplow that I adapted as a frame mount. Mitsubishi quality is very good.
Pros: Engine is more powerful than advertised, same engine as 28 horse tractor. Strong 3ph lift capacity, Heavy
Cons: Paint on the frame is a little thin in spots, but doesnt keep me up at night. Check loader bolts often, they loosen easily.
