Snapper RERIDER12.528 Reviews
5.00 star(s)
brian1963
RERIDER12.528 Snapper
Briansandrews@hotmail.com
Model Year: 2006
Front wheel bearing must be greased regularly or bearing will fail resulting in wheels falling off. Also, front tire tend to go flat over winter storage. A couple of tubes would probably correct the issue, but I just re-inflate them and they are good to go. Otherwise with good care, regular service, and indoor storage, they will last for decades! Not much of a "tractor", but it will do until I am able to get at least 8 acres and can get a small, old IH!
Pros: Easy to transport, easy to change blade (it stands up on the end), rear engine so easy to drive/steer.
Cons: Annual wheel bearing grease mandatory. Front tires go flat during long storage. Mine needs non ethanol free gas and won't start at all with old gas.
4.00 star(s)
choopes
Snapper RER Series 8
Model Year: 1985
It's best feature is simplicity of design. Has one belt. No censors. One 30" blade. In a world of "throw away" devices, finally here's one made to be maintained indefinitely!
Pros: Cheap solution to cutting my 2 acers.
Cons: Things wear out.
5.00 star(s)
calrec1
2005 Snapper 12.5Hp 28" Hy-Vac Deck
Model Year: 2005
I found this lightly used machine on Craigslist and drove over 150 miles to bring it home inside my Caravan. Bought it because of the uncomplicated Snapper drive train. Also bought it because of its rugged construction.
Pros: Ease of maintenance.
Cons: Would like improved steering.
