Bucket Level Indicator--A New Approach
   / Bucket Level Indicator--A New Approach #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
I've been filling these cold winter days with fabbing and testing this bucket level indicator. It's an idea from a friend in New York State who built and has been using his for about 10 years. He used connecting rods rather than the 1/16" cable on mine. No particular reason for cable other than easier adjustment of length while calibrating. May use rods for permanent installation.
The pics show the leveler mounted on the outside of the right loader arm which makes it a little easier for calibrating since the loader valve is there. The round silver object is a 5" diameter neo magnet, again handy for testing. It's super strong and can only be moved by hitting fairly hard with a soft hammer and could probably be used for permanent mounting.
The 1st picture shows the loader raised with bucket level, the next shows loader raised bucket not level, the third shows loader at ground level with bucket leveled. The last picture shows the leveler on my friends tractor where the rods are used to operate the indicators.
I'm not sure if there are other methods, out there, that will show bucket level with the loader raised. This one is handy in that "bucket level" can be shown prior to dropping the loader to ground level which saves time while moving back to the "pile" and dropping the loader for another load. Showing bucket level with loader raised is very handy for something like forks where level is normally difficult to see from the tractor seat.
Questions and suggestions are appreciated.
Edit: To clarify---The white pointer (first three pictures) is "stationary" while the "silver" one is attached via cable to the loader frame upright and the curved "quadrant" is attached via cable to the loader bucket.
   / Bucket Level Indicator--A New Approach #2
Looking good! Can you explain in more detail how the bucket level measurement is achieved, not just the indicator.
   / Bucket Level Indicator--A New Approach #3
This is very interesting. I would also like to see an A to Z installation to understand how it works.
Let me think about what I can do to clarify how the system works. It's rather simple in concept but it took me a while to really understand it. I was confused even while building and assembling the components just how the thing works. It's similar to how a mechanical self-leveling loader works in some respects.
Thanks for your interest and happy to answer specific questions.
Sorry, duplicate post.
   / Bucket Level Indicator--A New Approach #6
Looks good! I really learned the importance of the indicator when I started using the front blade for snow. With skid shoes a slight change was the difference between leaving 1" and leaving 1/4".
   / Bucket Level Indicator--A New Approach #7
Very interesting...would like more details.
   / Bucket Level Indicator--A New Approach #8
Maybe take some pictures from the side showing the linkage and mounting on the bucket to start?
   / Bucket Level Indicator--A New Approach #9
Let's see if I understand. The cable going towards the rear pivots the scale with boom movement and the one going forward moves the pointer based on the curl?
Actually the opposite. The pointer is moved by the cable going towards to the rear attaching to the loader frame upright. The quadrant is moved by the cable going to the bucket.
I have some additional pix to post and will include a detailed description of each step of the build. Will hopefully get that info posted yet today. Thanks for your interest everyone.
   / Bucket Level Indicator--A New Approach #11
View attachment 494921View attachment 494922View attachment 494923
It sure is easier to see.
   / Bucket Level Indicator--A New Approach #12
That's my interest in it. I haven't used any indicator except the level metal on top of the bucket. Seems like the sliding rod types would be hard to tell where you are relative to level. Something like this could be scaled easily.
   / Bucket Level Indicator--A New Approach #13
Looks good! :thumbsup: :cool2:
I still haven't figured out how you manage keep tension on those cables, but I'm sure it will be explained.
   / Bucket Level Indicator--A New Approach #14
Following. :)
   / Bucket Level Indicator--A New Approach #16
Do you have an SSQA loader? You said the cable attached to the bucket so I'm guessing, no.
   / Bucket Level Indicator--A New Approach #17
I'm curious as to how this works. Looking forward to more pictures.
I will post each picture or two in a separate post to avoid confusion.
This first one shows the 5" diameter magnet attached to the right loader arm but would normally be attached to the left inside to keep it out of harms way. The neo magnet is super strong.
There is a 3/8" hexbolt shown with the head in the clearance area on the backside of the magnet. I used a longer bolt and then cut some of the threads off to keep more bearing area for the pivoting components..
This shows the addition of the white plastic pointer. I started out with a metal pointer (1/4" x 1" material) but the magnetism flowing thru it was enough to affect movement of the other metal pointer. Probably will make a new one out of aluminum since I kind of messed up the plastic one with too much heat. :)
The white pointer shown is clamped in position via the 3/8" hexbolt to not move once its position is established. When it and the other pointer and the reference mark (yellow) on the quadrant are lined up the loader is at ground level with the bucket level. Could call this the "starting position".
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
