Ratchet(ish) Rake
/ Ratchet(ish) Rake #1
chim
Elite Member
Lancaster County, PA
Kubota L4240, Ford 1210
There's some cleanup to do here that will involve a fair amount of scratching. Since there was a piece of 6x4x3/8 galvanized angle in the scrap pile at work, I thought I'd give it a try. Since the material was mostly galvanized, it involved some grinding. When I weld galvanized steel, I run the grinder over the weld areas till the wheel throws a decent shower of sparks.
The teeth are on the 4" leg of the angle, and the 6" leg extends back under the bucket's cutting edge. Three smaller pieces of angle wrap up over the bucket edge to keep it in place.
Two chains, welded to the top of the 6" leg go around the back of the bucket. I found a couple long 3/8" bolts and some rod couplings to secure the chains at the top. The original thought was to use the slotted angle for the bolts, but the angle they would have come through didn't look ideal. It seemed better to drill a hole in the bucket for each bolt to pass through. The way the chain wraps around the bend in the bucket worked pretty well.
I assumed that the threads of the bolts would get messed up where they pass through the hole, so I stacked two rod couplings and tacked them together. The rod coupling that is against the bucket is a shortened 1/2" coupling. Its purpose is to provide a free and clear spot for the 3/8" bolt threads. I rounded the end that goes toward the bucket because even with this location, the bolt comes through at a slight angle.
I ran it through some testing and it worked fine. With the bucket level and the teeth perpendicular to the ground, it scraped and gathered the "viney veggies" in the fencerow. With the bucket dumped so the teeth attacked the ground point-first, the teeth dug little furrows.
Had a great day today! Life is SOOO much better since completing the welding table. Till now, the choices were to throw a piece of plywood on a pair of saw horses, or grovel about on the ground.
/ Ratchet(ish) Rake #2
Nice! Post some pic later to show how it wears please! Great exicution. :drink:
/ Ratchet(ish) Rake #3
Well done! Agreed, I want to see how it wears too. I've been thinking about fabricating one that's dual purpose-
One way would act as yours does, to remove vegetation from the ground, the other would act as a toothed cutting edge, like the piranha tooth bar.
/ Ratchet(ish) Rake #4
Those teeth will be perfect for reaching up on trees and ripping those vines right off the branches.
They look to be at the perfect angle.
I did it with the Piranha tooth bar but had to keep bucket at the dump position.
Nice job. Gonnah paint it orange right... :thumbsup:
/ Ratchet(ish) Rake
Here's a picture from yesterday after I used it to erase some 50-60' ridges in the back yard from a dog run. Then to scrape some dirt loose to fill in a few holes. The ridge area was shaped like an "M" about 3' wide where the dirt was pushed up and hardened. This involved trying different angles of the bucket to see what worked best and the front wheels of the L3200 were off the ground a number of times to get enough down pressure. The upper points of the M had to be scraped down to the valley and the whole thing raked smooth.
/ Ratchet(ish) Rake #7
No appreciable wear-and-tear yet (at far as I can see)! Well done! :thumbsup:
/ Ratchet(ish) Rake #8
Nice job man & yeah a welding table is worth it's weight in gold to help make a project easier to work.
/ Ratchet(ish) Rake #9
I’d weld a triangle brace behind every tooth. Otherwise there’re probably going to get bent.
/ Ratchet(ish) Rake
I had thought about that. It could still happen if I start having bent teeth. So far. it's been one of those "If it works, don't mess with it" situations. I do have a concern that if the teeth did have the triangles, the triangles may act as ramps and guide things over the teeth, rather than allowing the teeth to grab them.
The angle is heavily galvanized. When I weld something like that it takes some time to get down to bare steel.
/ Ratchet(ish) Rake #11
Excelent job. Looks great. I have looked into the ratchet rake but the cost to get it to Canada is absolutely rericulous. I could use one to "fire smart" my property from forest fires. I can't believe that I have never thought of this idea but I am sure glad you did. Only one problem that I can see is....It's another project i have to do that I don't have time for. I'm still trying to find time to finish my land plane. I might try to make mine to bolt to my 48" grapple tines, that way I could drag stuff into a pile and pick it up with the grapple.Thanks for posting
/ Ratchet(ish) Rake #12
Some one has a bunch of nice gusset's on hand for future projects! :laughing:
Very nice chim:thumbsup:
/ Ratchet(ish) Rake
Thank you. I've been using it and so far no problems with bent teeth or anything. Stomper made mention of having more projects than time, and it seems I'm usually in that mode. There are things I'd rather be doing, but the big project right now is cleaning / organizing the garage. It was either that or a guest appearance on "Hoarders".
Year: 2018 Make: GMC Model: Terrain Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 116,222 Pla... (A66738)
Year: 2018 Make...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
Jeep Metal Tailgate Metal Decorative Sign (A66738)
Jeep Metal...
2020 KENWORTH T880 TRI-AXLE HYDROVAC TRK (A67714)
2020 KENWORTH T880...
PORTA POTTY (A68842)
2017 Chevrolet Impala Sedan (A66738)
2017 Chevrolet...
