Boom pole for front end loader
   / Boom pole for front end loader #1
futuresweets10
I am looking into building a boom pole for the front of my back hoe that will clip on the front of the FEL bucket. I plan on making the pole somewhere around 12ft long, but am not set on a length. (similar concept to this one HORST WELDING | HLA >> TELESCOPIC BOOM POLE (STANDARD OR HYDRAULIC ACTIVATED)). Anybody ever seen or made anything like this? Any advice? how much weight could I potentially lift with a set up like described?
   / Boom pole for front end loader #2
I built one out of 2x8's when I built my pole shed for placing trusses. I had it sitting in the bucket with bracing going all 4 directions. Some here would tell you the dangers,:D I will not!!! Worst problem was slowly cracking the valve on bucket to keep it from reacting to quick. Other then that it worked great.
I take it your Cat is up a running pretty decent now?
Knock on wood, cross my fingers, and anything else I can think of for good luck..... Yes, it seems to be doing good.
I have a 16ft 3in round steel pipe I was going to build it with. I was thinking about putting it under the bucket (with bucket sitting flat on it and welding a cross bar to the tube that runs along the front of the bucket to keep it square and then having a clamp type set up to attach it to the bucket..... I know I suck at describing things.
Lets see if I can describe this better.... The green is the pole. The blue parts are 2x3 box welded to the pole. The yellow is metal hooks welded onto the front blue bar. I would drive the loader up to the assembly and tilt the bucket to get the front lip in the hooks then level the bucket to pick up the boom pole. I would then chain the assembly to the bucket to keep it from being able to move..... This is similar to how a bobcat (or skidsteer) bucket hooks up....
   / Boom pole for front end loader #5
I made something similar, but not as advanced. We (I) wanted one quick, my buddy wanted to lift the trusses by hand, and I am ummmm, Lazy so wanted a boom pole so I made this one to anchor onto his bale spear and give us some height.
The sky is the limit for how creative you get in your mounts. My Backhoe has big U's on the bucket to hang my forks on, if I was going to use it on that I would have built something along the lines of my hang on forks.
Weight limits? Who knows, afraid I would get sued if I put any numbers out there :)
Any idea how long that pole you built was?
   / Boom pole for front end loader #7
I just measured it, and I used a 10' piece of pipe.
Just realized I left off the picture of the "hanging"
I hate manhandling stuff like that into place, it goes so bad when it goes wrong.
I know the feeling. When I did my shop we had to put steel trusses on the top of 6x6's 12ft in the air. I had two people helping me and we built walk boards along the 6x6 posts and tried to do it by hand. After about 5min of attempting the first truss I broke down and rented a pull behind JLG lift from home depot. About an hour with the lift behind my 4 wheeler and all 5 trusses were set.....
I didnt have my back hoe way back then and need to lift alot more weight than a JLG lift will hold now. Im building something similar to whats in the pic and have all done but setting the top pole
   / Boom pole for front end loader #9
I had two people helping me...
Here is how I do it. I made a 3-pt hitch for my loader and installed a
rock rake frame. The frame (with rake removed) has square tubing that
allows me to fit some schedule 80 pipe in it for a boom pole. I welded a
hook on the end.
I can reach up 16 feet and lift several hundred pounds.
Here I am setting trusses, and I had no helpers.
   / Boom pole for front end loader #10
Futuresweets10, of course with anything weight vs. fulcrum, But if you have braced good for amount of weight I would think it should work. Far as weight, a careful experiment would need to come in play. With that extra extension out there you could bend bucket cylinders. Dfkrug probably can give you good examples of that.
I do likeDfkrug's idea. Dfkrug has alot of nice builds you should check out.
Alanb has a nice setup there also.
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
22008 (A51694)
22008 (A51694)
NEW Wolverine Skid Steer Bucket Root Rake Attachment 34'' (A53002)
NEW Wolverine Skid...
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
NEW Wolverine Skid Steer Trencher (A53002)
