25 HP Rated Rototiller on a 45 HP tractor?
   / 25 HP Rated Rototiller on a 45 HP tractor? #1
SpringHollow
Elite Member
South of Rochester, NY
Power Trac 1850, NH 2120
I have a Woods T50 50" rototiller that I used with my Ford 1520. The rototiller is recommended for use on a 15 - 25 HP tractor and it has a slip clutch. Is it okay for my brother to use this tiller on his Ford 2120 which is a 45 HP tractor? Will the slip clutch on the rototiller protect the tiller from too much power? If not, is there a slip clutch or something else that one can buy that would protect the tiller?
Pardon my ignorance and thanks for your help!
Ken
   / 25 HP Rated Rototiller on a 45 HP tractor? #2
If it has a slip clutch make sure it is adjusted and slipped correctly... and just take it easy..
Soundguy
   / 25 HP Rated Rototiller on a 45 HP tractor? #3
I borrowed a tiller from a friend, I think he has around a 30hp Kubota, I have a 45hp MF. I used it for a little bit and then ended up splitting the PTO shaft at the slip joint, the clutch never slipped. It may have been that the tiller sat further away from my tractor then his, but that is the last time I borrow a attachment, cost me enough to replace the PTO shaft, I should of just rented one.
Dennis
   / 25 HP Rated Rototiller on a 45 HP tractor? #4
If the slip clutch is adjusted, I really don't see why it would matter.
   / 25 HP Rated Rototiller on a 45 HP tractor? #5
Yes, but you're not going to like the price. See 8254174 AX4 480MM/19 1 3/8 QRSPL X 1 3 - Agri Supply (plus freight). And don't bother shopping around, cuz AgSupply has about the best prices going for PTO stuff.
If you do swallow the price, adjust the clutch to slip at 25hp. That way the 45hp tractor can't wind up the 25hp tiller tranny too tight. Instructions on how to do this should be included. If not, I can help you out there too.
//greg//
   / 25 HP Rated Rototiller on a 45 HP tractor? #6
I agree for the most part. If the slip clutch is adjusted properly or the right sheer pin is used you should not have to worry as long as the operator knows what they are doing, otherwise the weight of the bigger machine might bend something when/if he turns or is not going straight when he drops it.
   / 25 HP Rated Rototiller on a 45 HP tractor? #7
Ken
If the tiller has a slipclutch and it is known to not to be siezed up and is properly adjusted, buying another slipclutch is a waste of money. The slipclutch will protect the tiller from too much torque input, but your brother must be careful not to let the slipclutch slip to the point of ruining the friction discs or warping the pressure plates and heat damaging the springs. There is more chance of clutch damage than tiller damage.
Wow, replies 3 years later !
My brother has used the tiller a lot on his 45 HP tractor with no problems.
Ken
LANESHARK LS2 LOT NUMBER 198 (A53084)
LANESHARK LS2 LOT...
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
2239 (A51244)
2239 (A51244)
UNUSED KIVEL QUICK ATTACH TRAILER MOVER (A51248)
UNUSED KIVEL QUICK...
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
2" X 3" ANGLE IRON UP TO 16' LONG (A51247)
2" X 3" ANGLE IRON...
