New Owner of YM2002D
   / New Owner of YM2002D #11
I have 5' cutter on my YM2020. Power wise it does not struggle even cutting sapplings that I have to ride down with the FEL.
As far as front end weight, in his origional post he stated he had a FEL. He will have no problem with the front end being too light with the weight of the FEL in front.
I guess I'm finished with this thread for now. I want to thank all of you for your helpful insight and advice. I realize that any decision is ultimately mine, but I have more confidence in my decisions after receiving input from others who might have dealt with the same issues in the past. I am reminded of the words of a wise man who one said, "Without counsel, plans go awry, But in the multitude of counselors they are established." Proverbs 15:22
Thanks again and see you on another thread,
Beetle
   / New Owner of YM2002D #13
I own a YM2002D with a 5' FMC cutter. It does fine on lower grass or stuff that's not to thick. It works fine for me because I take my time on thick or tall stuff. For me it works great because most of my mowing is trails thru the woods and grass is not that thick. I can cover more ground with the 5'. The truth is tho that the tractor would match a 4' rotary cutter much better. I also have a 5' finish mower I use around my house (appx 2 acres) and the 2002 is matched well with it if grass is mowed as you would around your house. Meaning don't let it get 10" high. I actually run the finish mower in 2nd range on the pto. The higher speed cuts the grass clean and I'm able to run at a lower rpm and still not overload the engine. I run at from 1400 to 1800rpm max. The weight of the FMC cutter is not a problem when my loader is attached but it does make the frontend light when loader is removed. This is probably more info than you were looking for. Winston
   / New Owner of YM2002D #14
I've got a ym2002 but in 2wd. Not experience with a rotary cutter, but I run a 72" King Kutter Finish Mower off the back and have no problems mowing 6 acres. Occasionally, I will put the PTO in the 768RPM setting and trottle down to about 1500rpm (I put a pto tack on it to make sure that I have 540 at that speed). Bogs down in the thick stuff then. Have a Bush Hog Loader, and Just installed a Block heater. (If you live in cold weather, you'll love it. go to John Deere dealer and tell them you have a JD750 compact, it's the same engine).
   / New Owner of YM2002D #15
Beetle
this is interesting, although is a 2 1/2 year old topic ... just so's ya know :D
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
UNUSED TOPCAT QUICK ATTACH TREE SHEAR (A51248)
UNUSED TOPCAT...
UNUSED FUTURE 19" EXCAVATOR RAKE (A51248)
UNUSED FUTURE 19"...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2430 (A51248)
2430 (A51248)
