Rear remotes now, bh6000 IN FUTURE ???
   / Rear remotes now, bh6000 IN FUTURE ??? #1
James.Hering
Clarksburg, MD
kubota 2230
Hello all, I am a new member here. I love this forum. I am an owner of a BX2230. I would like to get a hydraulic toplink now, but am considering a BH6000 in the future.
My question is, What remotes should I buy now for the toplink, so that I don't waste money in the future if I get a Woods Backhoe. I assume the BH kit comes with remotes and hydraulics. Would these be in addition too the toplink remote or would I use the BH remotes for the toplink.
I have been lurking for months, reading every thread I can on BH6000 and toplinks. I am still trying to figure out what I need to do.
Thanks for any advice.
Jim
   / Rear remotes now, bh6000 IN FUTURE ??? #2
Welcome to TBN.
I do not claim to be an expert in this department as I have no hyd top link or back hoe or remotes for that matter, but i have worked with hyd and understand the principles. (How is that for a disclaimer upfront using our common conjunctions?!!)
The remotes for a top-link and a bh are fundamentally different. For the tl you have a valve that controls a cylinder, whereas for a bh you are drawing on the hyd pump from the tractor directly through a power beyond port in the loader circuit, without any intervening valve to direct flow to the bh.
Flow with the toplink Pump - FEL valve - (PB) - top link control valve - 3pt - return. In this situation the remotes are connected to and controlled by the tl control valve.
Flow with backhoe Pump- FEL valve - (PB) - remotes (which must be connected through the bh valve or by a hose) - 3pt - return
I know that this is drastically simplified and assumes the FEL which is not a requirement, but it shows the fundamental difference between remote connections for a bh and top link.
The bottom line then is that the remotes are radically different and therefore would not be duplicated in a top link install.
I hope that is clear--if not I will try to clarify or allow someone who has experience in this more specifically explain.
Mike in Warsaw
   / Rear remotes now, bh6000 IN FUTURE ??? #3
That is the question, isn't it. The Bx2230 was never designed to accept a Backhoe, however with the Woods kit, it works. Your dealer may know if the rear hydraulics kit is compatable with the BH. Considering the rear hydraulics kit costs less than $300 if you install it yourself, and the BH is around $6000
I wouldn't feel bad starting with the kit first. Even if it doesn't work with the Woods BH, you delayed that big investment awhile.
Best of Luck
2012 Ram 5500 4x4 Dump Truck, VIN # 3C7WDNAL1CG223770 (A54865)
2012 Ram 5500 4x4...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2015 Freightliner Sprinter 3500 Cargo Van (A55852)
2015 Freightliner...
2025 JMR 36in Mini Skid Steer Bucket (A53421)
2025 JMR 36in Mini...
MISC TOOLS (A55745)
MISC TOOLS (A55745)
