50 hr service filters
   / 50 hr service filters #1
jeff77indy
Grantsburg, IN.
2007 4110 Mahindra w/ M112 loader and Kubota B2910 w/ loader.
I don't have time to get to my dealer for filters would one of the dealers here on line ship them to me?
2007 4110 with spin on hydraulic filter.
Would like to double up on some filters.
PM or e-mail me at mcbarsranch@outdrs.net
Thanks
   / 50 hr service filters #2
Hi jeff,
why don't you try calling up the Mahindra 24/7 Owner care system (1-866-430-4415 tollfree number) and palce an order, iam sure they will help you out......:)
Is the spin on hydraulic filter on the newer 4110's the same filter as the one found on the 3510?
Also I Googled the recommended trans/hyd. fluids and found that most fluid for AC ,JD, MF etc will work. So my AC 821 PF will be good.
Jeff
   / 50 hr service filters #5
Jeff
Jeff, both the 3510 and 4110 share the same filters. There are slightly different Hyd. spin on's for older units but they have to be much older. The newer units have a larger spin on filter (around 9" long) whereas the older hyd. spin on is only about 6-7" long.
new hyd. spin on - #12305152100
old hyd. spin on - #15645153410
   / 50 hr service filters #6
We would be happy to ship you filters. Feel free to give me a call: toll free 1-866-393-0642 or you can e-mail me sales@www.NewEnglandTractor.com
We also have parts ordering online (if you have the part number) type it into the shopping cart fill out credit card info and we will get them out to you. New England Tractor . Click mahindra parts in the center of the screen, then click on the button for you have the part number, which you can also search by description( such as Filter) but some of the descriptions list only 1 model even though it fits multiple models.
thanks
Scott
   / 50 hr service filters #7
I know this is an old thread, but just to keep it accurate...
As of today, 02/25/2010, the Wix cross reference on wix.com lists the OLD filter above as the correct one for Mahindra 3510. It certainly is NOT as of at least 2004 (my tractor), which uses the "new" version listed above.
Hope this helps others avoid troubles.
- JC
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
WACKER NUESON PUMP PT2A (A52472)
WACKER NUESON PUMP...
2021 Doyle 8 Ton Trailer Tender (A52748)
2021 Doyle 8 Ton...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
