kubota gas eng.help, runs then shuts off 10/mins
/ kubota gas eng.help, runs then shuts off 10/mins #1
barahk's tree
I have a kubota 3 cyclinder gas engine on my 1997 bucket truck it starts and run fine until it warms up 10/15min.then it just keep shutting down,i have replaced the coil and it still does it... i drained the bowl on the carb and found it clean .since i don't have a owners manual i am limited with some info... any help would be great,.... does this motor have points or is it elctronic?:cool: thanks jody
i don;t think it 's the carb cuz it runs fine for a good 10/ 15 mins
/ kubota gas eng.help, runs then shuts off 10/mins #3
Look for fuel lines that might be collasping. It sounds like it might be a fuel line or something that is closing up once it get's warm. Or some other vaccum line.
/ kubota gas eng.help, runs then shuts off 10/mins #4
Check the vent in the gas cap. If it's plugged it'll run a few minutes then die. after a while it'll do it again.
Just run it till it quits, unscrew the cap and try to restart. If it runs it's the cap.
/ kubota gas eng.help, runs then shuts off 10/mins #5
You might also check for voltage at coil input after it dies. This would indicate ignition module or pick-up coil on crank or in distributor if no voltage present.
/ kubota gas eng.help, runs then shuts off 10/mins #6
Does it start right back up? Have you pulled a plug wire when it quits to see if you have spark? No spark, ignition. Other wise fuel problem.
ron
i will try all these today and let you know.... thanks for all the help- has any one herd of the moduals going bad on this motor (wg 750)?
/ kubota gas eng.help, runs then shuts off 10/mins #8
Barahk's Tree, were you able to resolve this issue? I ask because I am having a similar problem with a dual fuel three cylinder Kubota (DF750E).
/ kubota gas eng.help, runs then shuts off 10/mins #9
I had a Kubota gas mower that did something similiar to this. The ring on the gas lid fell into the gas tank and melted. It was laying right on top so I pulled it out. Some time later it started doing this. I looked at fuel filter and could see part of the melted ring in the filter, replaced filter and the problem was solved. Hope your solution is as simple.
/ kubota gas eng.help, runs then shuts off 10/mins #10
seen this happen before on other engines
